crazyjr
crazyjr's Avatar
05.02.2007, 01:32 PM
Originally Posted by chopndroptx
OK I have 2 almost exactly the same setups. 1 stock plastic Pede, and 1 full aluminum Pede.
I have them both programmed exactly the same.
Stock Pede
MM5700
12/90 gearing
Trany notched for more air to motor
And my motor temps are getting up to 180-190 degrees!!!!!!!!
FLM Pede
MM5700
15/86 gearing
Aluminum trany with nothing surrounding the motor
Motor temps run between 130-150, usually 140.
When I tried running 15/86 gearing on my Stock Pede the temps got up to 240 before I caught it.
Nothing is binding, and mesh it good. Both are running the same batteries, 7 cell IB4200's.
Why am I getting 40+ degrees more with the stock Pede with lower gearing? And 90+ degrees with the same gearing as my other Pede?
I dont hear anyone else complaining there temps are getting to high in there Pedes with stock tranys. Im wondering if my motor is defective. I already emailed CC but Im sure it will be a week or so before I get a responce. I need to swap motors and see what happens, but I havent had time.
I see two things, that stand out imediately. 1; the first may be waaay undergeared and overrevving, you may need to regear to about 18/90 to help contol the heat. 2; the stocker has a plastic motor plate and will get hotter because of lack of cooling from the motor plate. If its not thermalling, 190* is acceptable by castle for heat
