Thread: Lehners are in!
Cartwheels
05.03.2007, 12:45 AM
Originally Posted by MetalMan
You prepared to deal with 4mm shafts?
Is there a sleave or a bushing that can be used with a 5mm pinion so that it will fit the 4mm shaft. Awhile back I bought a pinion from Mike that had that same kind of deal, a sleave that fits into the pinion which made it fit a 5mm shaft.
What is the proper name for those? And where can they be purchased from?
