05.03.2007, 01:06 AM
Well, if the Y gaps are bridged (by melting solder or anything really) while the D gaps are still bridged, "bad" things most probably will happen. It'll probably short out the controller. But, since those traces are attached to the wires, you'd have to have a heck of a lot of heat to melt the solder since the wires and can will sink the heat away. I'd be more worried about the motor itself if it got to solder-meltings temps!
