Originally Posted by Serum
no, that's not the case. If you installed the software as an admin, you should be capable of using it, unless it's using network sources that are restricted to your account, but that's not the case.
Sounds to me like you need to manually install the driver. What does it say in the system manager when it's installed?
Hang on.. i just looked;
Here; C:\Program Files\Castle Creations\Castle Link
Check the driver uninstall folder, and execute the UninstallWindows2000andXP.bat.
Got up to there, ran that file and it says "Device Not Found"...
