05.04.2007, 06:59 AM
Thanks for all the comments - actually the weight is almost exactly the same as the conversion Mike has done on his losi-8T - he is running 5000 4S and me with 3700 5S - the weights are about 6 oz different - (mine heavier) total is 9.6lbs without body - Mike and i ran it last night and it goes quite well - it will even flip over with too much throttle (on the road) - absolutely no shortage of power - its set up for 35 ish for racing - SJCROSS - let me know if you remember where you saw the supermaxx:005: , Joeling - i havent run it on the track yet ( this sunday ) it seems not too bad on the balance though, Jollyjumper the design is mikes design, but i changed some stuff on it - ( rotated the motor up 30 degrees to make clearance for the speed controller ( which is recessed into the 7075 chassis to help get rid of the heat ). Thanks for the encouragement there Dafanapolis - Captain - I thought papa sold his emaxx last year, but i dont remember exactly what it looked like. It ran so good that i didnt want to hit the cnc machine last night - thats saying a lot...
Hows that "Hope and Change" working out for Ya???
