ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.04.2007, 10:44 AM
ahhhh, thanks! i knew the rubbing must be something i didn't do right. so the washer needs to go in between the 2 bearings, or just on the outside of the outer bearing (in between the outer bearing and the hex)?
i guess i'll have to get an order in for the UE ext cvd's. i also plan to get a UE titanium dogbone to replace the (too short) dogbone that comes with the FLM chassis. anyone know if this size is 100.5mm, or 105mm?
thanks again mattymaxx!
Eflite Blade 400 heli on 3s
