Thread: E-MAXX woes!
SixShooter
05.04.2007, 07:13 PM
Originally Posted by GorillaMaxx360
if you want a spool efect you can go with heavy fluid in the rear in the hb diffs. FYI just incase you did not know to use the hb diffs you have to buy flm hybrid bulkheads.
This to me would be your best bullet proof route in my opinion but I would try ditching the spools first since I'm kinda cheap lol I personaly run 5k in both diffs ( basher only) and it works fine. I get some slippage but the truck is more controllable now instead of with the spool. I'm pretty sure they make some thicker stuff like 10k if you need a little less slippage.
