05.05.2007, 07:35 PM
Cab... Yes the truggy diffs sort the gearing out perfectly. I'm running one of Dafs center diff setups and the 43/10 truggy diffs now and I run from 13T to 16T pinion gears depending on the surface and siutuation. The truggy difs put you right in the sweet spot for pinion choices.
The center diff and truggy f/r diffs are the perfect setup IMO.
to make it...
or break it...
Silent...But Deadly
