05.05.2007, 07:42 PM
I had this issue when I installed mine too. I got a set from the very first batch and when I installed them the output pins were slighty to long. I had to split the bulks to get them in. I told Mike about this and he said that he had made the adjustment for all future production. Did you get some of the very first release? Any newer ones out there should not have this problem.
I'm planning on changing out the outdrive pins on mine when the first time I tear them down to replace fluids and stuff.
Even if you have to split the bulks its not that hard to do. Just a few screws and the bulks split and they drop right in.
to make it...
or break it...
Silent...But Deadly
