05.06.2007, 12:32 AM
Thanks so much for the info.
How is the "cheapo" 8000 pack working for you besides for the temp, since you mentioned, it stays cool. If I run 5s, then I can gear down to a 14t pinion since I will have the additional speed from the voltage increase. I also am not sure about the size Truerc 5S 8Ah pack. But I tested the size of the Max Amps 4s 8Ah pack and it actually fits perfectly in all directions. I am just slightly worried about how hot it will get.
Is there any fan that is recommended thats bolts right on to the MM esc with few if any modifications?
Thanks again.
