yj-7
yj-7's Avatar
05.06.2007, 09:53 AM
Originally Posted by HotnCold
I like it too... The only thing that i would do if it was mine - would be to put some foam or double sided tape on the aluminum battery stop - to prevent the rubbing of the aluminum on the battery holder from scraping thru the end of the lipos - and maybe some velcro holding both batteries from sliding away from each other.... Other than that - looks great...
Thanks for the words of advice hotncold, and I will probably put velcro on the batts to keep them tight. As for the end of the batts. have you seen Tru RC's packs? They put somthing on the end of the packs when they build then so the end of the cells are protected. But I will keep an eye on that to.
