Patrick
Patrick's Avatar
05.07.2007, 04:56 AM
Sometimes even if they're bad they may have a no load voltage that looks good, but as soon as you put a load on it (maybe even just a couple of amps) the voltage will drop right down while the good cells should hold fairly well.
If you test it with a load, it's best to charge the pack first other wise even the good cells may look bad.
