Sower
Sower's Avatar
05.07.2007, 05:41 PM
Hey guys, thanks! The battery tray was an idea I stole from someone here on the forums. Just can't remember who :002: I ended up modifying their design a little. Instead of velcro for the top support, I used CF and body pins.
Basically the tray is two pieces of 1"x1" angle from Graphite Elegance. You put the two together, and then use a smaller section of it at each end. Then I used two battery posts for the top strap of CF. The posts act like a fastening bolt for the screw through the bottom of the chassis. It ended up working perfectly. Hope that all makes sense:032:
