jnev
jnev's Avatar
05.08.2007, 10:18 AM
They stand up to brushless really well. You shouldn't have to upgrade anything for a few packs. But eventually, the wear will start kicking in, and the diffs will probably die. So if you want to be safe, Then I'd recommend MIP CVD's front and/or rear and MIP super diffs in the front and/or rear. With this set up, you should be fine with almost any setup.
A MM is a little too much in a such a small rc like this one IMO.
