zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.08.2007, 08:08 PM
A4, also, I was looking at the other pics. Why do you have the slot where the Quark mounts? Was this supposed to be THE Quark case instead of the alum. Quark case?
If that is the case (no pun intended), then that would work fabulous for dissipating heat as there is only the FET's and the then the heatsink, and you definitely would not need fans.
