zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.09.2007, 10:07 PM
I sent mine off to S&T, they said they would just replace it, no questions. The electrolyte would have damaged the board, as well as when there are no caps, there would have been damage done to the board.
I have a really good plan for a custom Quark case, I just need the distance from bottom FET surface to top FET surface. It will be about 1cm wider than the stock case though.
It will not need adhesive either, just regular thermal compound, which is nice.
