05.10.2007, 10:15 AM
Andy is right, the cap would not have caused it. Using a cap with a higher voltage rating than needed is actually good since it won't be running close to the max rating. And those electrolytic caps usually come in v ratings of 6.3v, 10v, 16v, 25v, 35v and so on.
At most, a bad cap could maybe fry the BEC chip if it somehow internally shorted. But most BECs have a thermal and short-circuit cutoff.
After looking at the datasheets for the part numbers you posted, one is a FET driver IC, the other is indeed an output FET. Driver ICs don't usually go bad since they are low current devices. I would think that whatever caused that one to go bad, might have fried others as well.
Here are the datasheets if you're interested.
IR2102S datasheet
IRF7413 datasheet
