zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.12.2007, 10:27 PM
oh oh oh, no no, there will be no epoxy to be had in this case, just thermal paste, arctic silver. It does clamp the board, so you don't need/want epoxy, and you can always take it apart too.
I have to get the distance right between the two plates, as to get a good pressure (but not too much) on the FET's for good coupling.
I am just modifying it right now, with heatsink bottom, and motor mount holes. It should be good.
Thanks Mach1stang! :027:
