Originally Posted by OldSoldier
All,
This is a great thread because I'm having the same problem with my Tbonz. I'm using RPM arms. My RPM suspension arms are the same size as my stock E-Maxx (pre-WideMaxx) suspension arms. The Tbonz are about 1/4 inch too short and I don't understand why. I have the Fastlane Machine Chassis with the combo diff carrier/bulkhead with 1/8th scale diffs. I bought it all from Monster Mike.
I hope my LHS has some 3.3 sliders if that is the answer.
OldSoldier
Old Soldier
The T-bonz should be working for you? Do you have the pivot balls screwed in all the way? Also, check to see if you have too much suspension travel....you may have to reduce just a tad but the t-bonz should work.
