05.13.2007, 05:35 PM
Nope, the diffs should be just fine. Of course, over time, you are gonna want to change the fluid as it'll probably get dirty (as any diffs do).
No one knows about the spurs yet. I wouldn't go buying Mod1 just yet, because I think the spur for the .5 will be 32p, but not sure yet. Hardened pinions would work as long as the gear mesh is VERY solid, but finding a small hardened pinion (~13T) that is Mod1, yet with a 1/8" bore can be difficult.
A normal servo should fit if you cut the mounting tabs off and stick it down, but it probably would weigh more. I would measure just in case.
