Finnster
KillaHurtz
Finnster's Avatar
05.16.2007, 05:20 PM
Originally Posted by Serum
Welcome to the forum.
Quite a familiar username you picked.
You use a Y cable on channel two to make it happen; on 1 side you hook up the esc, and on the other the braking servo.
Yeppers, in addition you want to make sure you have the reverse disabled on the esc obviously. :)
Now the (mechanical) reverse is a diff story. You will need a 3rd channel for that, but they are notoriously weak and heavy, so most do the FOC (forward only.) There is not a way to have motor reverse and mech brakes either, unless you tried brakes on a 3rd channel.
