05.16.2007, 11:30 PM
Here's an update I found a Neu 1506-1Y 5500kv motor for the CRT.5 time to see what a high end motor does compared to the Mamba motor?
I just got a Eagletree micro logger with a brushless rpm sensor and 2 temp sensors I'm going to try and get some good data on the Mamba before I install the Neu motor and compare the data see where the diference is and if it is worth the extra 100 bucks for the Neu? Hopefully the Mamba Max esc will run the Neu without cogging if not I may try the Quark 80amp esc.:032:
This should be interesting.:005:
