OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
05.17.2007, 10:43 PM
Originally Posted by ssspconcepts
Old Soldier
The T-bonz should be working for you? Do you have the pivot balls screwed in all the way? Also, check to see if you have too much suspension travel....you may have to reduce just a tad but the t-bonz should work.
Yes, you may be right about the suspension travel, but I found one other problem...the rounded dogbone end of the Tbonz are too fat to fit in the drive cups of the HotBodies Lightning diffs I bought to go into the Fast Lane Machine hybrid diff housing/bulkhead. I ended up shaving all four dogbone ends down considerably to get them to fit inside the drive cups. This is getting painful! Where did I go wrong?
