05.18.2007, 02:36 PM
The more ppl we can get, the cheaper it will be per unit. Mike still hasn't replied back yet though.
The stock Quark case is roughly ~60cm2, but also the thermal coupling between FET's and case is very poor. So this one has 5 times the surface area plus superb heat transfer from top and bottom FET's. I can bet under normal MT conditions the FET's will only get 10 degrees (maybe less) warmer than ambient temp, but just a guess.
Oh, there is no way I can make room for extra caps on this, it would simply be too large. Caps are going to have to be added to power leads externally.
