GriffinRU
05.18.2007, 02:47 PM
Finally capacitors being discovered by RC!!!
But keep in mind they only good if they close to FET's, very close, almost mounted on top of them. Cap per bank of FET's, otherwise you add inductance which doesn't help you at all, actually will cost you at higher RPM's...
While selecting capacitors in addition to ESR and Voltage check for 125C version.
