GorillaMaxx360
GorillaMaxx360's Avatar
05.19.2007, 02:35 PM
i only asked because i will be using it on my maxx with single speed buggy diffs, 2200 neu, 2p2s 8000maxamps. THe only reason i asked is because i wanted to know what the smallest number pinion i could use with the 51t and you said probably 18t Right. and i just wanted to make sure this was not over geared. Also can i get a slightly bigger spur to work with the strobe like 55t, so i have more gearing options because right now it seems that all i have is 51t spur and 18, 20, or higher gearing and that is not much on the lower end of the spektrum of gearing. that all. my truck is very similar to SSSP's
