luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
05.19.2007, 03:50 PM
Originally Posted by GorillaMaxx360
i only asked because i will be using it on my maxx with single speed buggy diffs, 2200 neu, 2p2s 8000maxamps. THe only reason i asked is because i wanted to know what the smallest number pinion i could use with the 51t and you said probably 18t Right. and i just wanted to make sure this was not over geared. Also can i get a slightly bigger spur to work with the strobe like 55t, so i have more gearing options because right now it seems that all i have is 51t spur and 18, 20, or higher gearing and that is not much on the lower end of the spektrum of gearing. that all. my truck is very similar to SSSP's
I have used 51 tooth spur on the strobe with 16 tooth pinion on my single speed gorillamaxx and i found out that is the lowest pinion this is my mr g2r revo if you will use it for bashing it will be alright with the quark monster pro with RCM heatsink with one fan but for racing i still had some thermal shutdowns on the the track when the temps here in Indiana went up to 80+ F but gearing it down will take care of the problem, Mike has bigger spur gears to put on the strobe,I think about 62 tooth spur,you might send hime a PM for that.
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
