Serum
Serum's Avatar
05.20.2007, 07:50 AM
Hi Monk; welcome to the forum; The phoenix is meant for stick transmitters, which basically start with throttle at 0 percent of the stick movement; The pistol grip transmitters start at 30-40 percent of the throttle. (where 30-40 percent is reserved for brake/reverse) Can you imagine what happens? :) this can be corrected with the use of a pixie though (small device that makes the pistol grip signal act like a stick transmitter; but then there are the brakes; the phoenix hasn't got proportional brakes. so you need a mechanical brake.
Starscream is one of the users that has this controller (or had, since he didn't know about the existence of this converter needed for the phoenix) i thought he mentioned about buying another one and try it again.
