Thread: Revo 22.2v
Eccentric
05.20.2007, 05:40 PM
Originally Posted by Finnster
Nice to see your turned out so well. What about temps?
I'm glad it's working well too. I'm new to the RC world believe it or not. So don't have a temp gun yet. I thought a nitro buddy of mine was going to stop by today but he hasn't shown yet. I was going to use his. I do have one coming.
Originally Posted by BrianG
I am surprised that you can't wheelie on demand. Are you sure the slipper is set tight enung? That thing should be able to just about flip over from the torque. I was running a 10XL on 14 cells and it would easily flip if I wasn't careful - and that's with the ESC set to soft start power! I know you are using the extended chassis, and that should definitely make it harder to do, but I still think it should wheelie like mad!
I re-read your first post again and see that you had a problem with the pillow balls popping out. I had that issue with the stock carriers, but not once I put the RPM ones on. Do the balls have any play? They should not have any in/out play, but not bind either. The pillowball adjustment may loosen over time too, so you might want to check that.
It might be the slipper I could check it. It's charging right now and I'm taking a food break. I'll adjust it and take it out again.
I have 7 packs though it today 3 yesterday and 2 the a couple days before. So a total of 12 (12 x 25min = 5hrs total). It wasn't just it popped out I have a sizable jump and landed bad the wheel is bent too. They also had Dry Ice on them so the might have been a bit slipper then normal. And who knows I could have had that one loose. Most of this build took place between 1:00am-3:00am. So I might not have been awake.
Originally Posted by starscream
Nice conversion,
I would recommend some angled aluminum to protect that Lipo pack. It's quite an investment and would be a shame if one accident took out the entire 6S.
I experienced the same low end power issue with my HV110. By default, the HV is setup for soft start. I set mine to 100% and that fixed the low end power loss but I now have a little issue where the throttle seems to get stuck, just a touch, once I start out. This issue is tolerable for now as appying the brakes stops the vehicle but its not ideal. Just like everyone else, I'm hoping the MMM will be available soon.
Where do you think I need it. It's hard to see the box in the pictures because it's clear. The box covers the bottom, outer side, and front. It was originally made to cover all sides except the top. But it didn't fit well so i cut off the 2 sides and trimmed it to fit in tight to the chassis. The poly under the ESC and the UBEC are the sides I removed. It also has a thin foam pad that is on the bottom and inner side to take some of the initial shock.
I like li-po and it doesn't really scare me but I still treat it with respect. I do plan on trying some A123s with my next Revo. So it's one less thing to worry about. Plus as I mentioned it's getting and RC-Solutions cage soon. Which from the pictures I've seen will need to be modified on that side. So I might add some extra support to the box using the cage as a mount.
So you think the low end power is the soft-start setting? I'll try the slipper first then I might try a different setting.
Thanks guys.
