Originally Posted by zeropointbug
You put the switch onto the esc's power switch wire, it does have one, doesn't it?
If you are going to use a switch at all, it would make the most sense to place it after the BEC, but before the receiver. That way, the BEC has a chance to
"settle down" after being plugged in. But, the switch on the BEC input would work too.
