Finnster
KillaHurtz
Finnster's Avatar
05.23.2007, 04:09 PM
Originally Posted by gasshead
you do know thaty with an electric motor you would still have reverse even tho you have the CD. so i would just keep the CD trans and sell the other one, unless you are gonna switch from nitro to electric. i also ground down the peice that holds the little brake arm thin from the front of the case. it looks better IMHO
Yeah, there would be nothing stopping running the CD in the reverse direction. I would have to disable the man brakes tho, and I'm not sure how motor braking w/ a CD would be. Seems like it would get wierdly balanced pretty unpredictable, but then again I've never tried it. The big diff in the trannies would be if I will like the CD or not, or at least having the option to quickly change between a solid center & CD. Aside from the small notches, everything is reversable should I decide to sell it or not. Perhaps someone would even want a locked tranny for their conversion? :) Either way, I have two clutches, one is modded, and prob will stay that way for a while until I see how it drives and what I want to do w/ it.
