tom255
tom255's Avatar
05.24.2007, 02:52 AM
OK
I have tried my LSP on track, actualy track is 30% trigger track . Times is pretty good seems even better than my nitro times. The torque helps lots with jumps. Jumps right after coner where no time for speed up ur car it easyly do without any problems when others nitroman just go through jumps with low trottle i like it. But in other hand Torque not so good on longer stright, pretty difficult go stright without problems when you dont control your trigger. But after 10-15 mins of driving skills goes better and better.
And now sad thing about after ~30min of driving car stops i thought maybe it thermaled but i saw how smoke comes out. Immediatly i ran to my car and smoke goes bigger and bigger. Damn how scary, then i removed a shell i feel then disconnected my battery its heat melting all around. I have realy bad Experince with BK so now i will order Chinese plane ESC control it though PISTIX adapter and use Mechanical brake. Enough expenses. Its way too expensive burn ESC
