Finnster
KillaHurtz
Finnster's Avatar
05.24.2007, 11:17 AM
Hey, that thar be me :) I'm using similar stuff on my V2 as I was so satisified w/ it on v1. LMK if you have any ?'s
FYI, I made some errors in the specs on the 1st post, which couldn't edit, so were updated further down.
The density is ~.9g/cc (floats) and is not quite half the weight of CF. However 1/8" material is a bit too flexible to be used as batt trays, 1/4" is much stiffer. IE, you end up with a thicker tray than CF, but about same weight, easy to work with and highly affordable. You could do some stragetic shaving to bring it down, but I never bothered.
I have a 1/8" strip that works extremely well as a roll hoop tho bc of the flexibilty.
