* Two-stage thermal shutdown protection protects the VXL-3s from overheating.
* Locked Rotor Protection™ prevents system damage by cutting power if the vehicle is stuck or the motor is bound.
* Sensor Phase Detection™ protects against improperly wiring aftermarket sensored motors.
* Sensored Motor Backup protection causes the VXL-3s to switch to sensorless operation if a motor sensor fails or sensor wires become disconnected. Sensored motors can be used without connecting the sensor wires to the sensor port on the ESC.
* Battery Over-Voltage Protection™ causes the ESC to go into failsafe mode if the maximum input voltage is exceeded.
Sensored & sensorless..... give me that in a bigger esc and I'll be a happy man- I could run all kinds of weird * wonderful BL motors..... A few redemming features then but I want a higher voltage model still- hurry up Traxxas. Right, now Im going to bed before me eyes drop out.
