05.26.2007, 04:36 PM
The Nikon says it will do 30fps, which should be fine. Cartoons are typically 15fps IIRC or less.
For instance, 40mph is 58 feet/s. So, you'd get one frame every 1.9 feet, which at 40mph is pretty good.
The Canon A620 (which is what I have and like a lot) will do 60fps.
Just remember, the higher resolution and frame rate you go, the more memory you'll need.
