05.26.2007, 06:11 PM
I take it you mean the centre sliders- I would get some proper metal CVDs- much much stronger. The rest of your list is fine.
The MM wont take 14 cells very well.
Specs
Cells 6-12 NiCad/NiMH 2-3s LiPo
Continuous 100 amps
Resistance 0.0003 ohms
Brake Proportional
Reversible Yes - with lockout
Low Voltage Cut-off Programmable
Size
ESC overall: 1.9 x 1.3 x 1.2"
Motor: 1.4" dia. x 1.7"
Weight
(w/wires) ESC: 2.5 oz (70.9 g)
Motor 7.0 oz (198.4g)
Connector Type Universal
I would run the 8xl on the MM with 12 cells. Gearing wise...... start at something like 25:1 overall, then maybe go up on the pinion a tooth at a time/ down on the spur a couple teeth until you find the 'sweet spot' for that setup.
