05.27.2007, 12:47 AM
Man, you really have bad luck with this stuff!
Anyway, the boards are connected by pins going through each board. On one end, the pins are soldered to both boards, so they won't come apart short of desoldering the pins. On the other end (near the caps) it is a socket/pin setup, so they can seperate.
