BlackedOutREVO
05.27.2007, 01:27 AM
Originally Posted by BrianG
Like I said, it shouldn't - at least not much. Typical fans should not pull enough current to affect runtime drastically like that. I would run without them on a cool day and see if it really is the fans that are causing your issues.
Judging by your other thread about your IBs, it sounds like your batteries may be the culprit since you are putting only 2800mAh back into a 4200mAh pack. Right there, your runtime is drastically reduced. If your fans were causing it, the charger would still be putting about 4.2Ah back into the packs.
and idk, it seams like the fans are, but then again idk, could just be me...
yes i think so also, idk that i have ever put more then 3000 in, i dont remember tho, hmmmm well this is kinda dumb then.... idk what to say
