05.28.2007, 02:46 AM
A dremel with a abrasive cut off wheel will cut the hardened CB like butter.
Was the 14t century pinion black? I dont think the 14t is hardened the 9-13t pinions are I think? there the black color pinions.
With the MM the 5700 is great on 2s for the dirt and if you want some sick speeds drop in a 3s for some on road fun. If your looking for longer runtimes and mostly drive on dirt then the 4600 might be a better choice.
If your going lipo get a pack rated at 100amps constant the 4000mah Maxamps pack I have rated at 80amps constant gets a little warm with the 5700 motor.:)
