05.28.2007, 07:56 PM
i have a couple of questions for you
1.) are you using 1/8 diffs and if so what size dogbones are you using for the front and rear that conect the diff cups to the transmission.
2.) what neu are you using
3.) what did you do to you quark to keep it from thermaling.
4.) how is the cg with that chassis
5.) do those shocks have nuts on the piston shaft to keep the shock rings from comming off or is there just e-clips
6.) how many cells are you running nimah or lipo
7.) what weight shock oil are you running
thanks nice ride BTW
