05.29.2007, 03:09 PM
Being two pole, that LMT should work well with the MM. However, the current it might pull may cause the little MM to heat up. If you have a MM, I would just try it out in slowly increasing speeds to see how it works. An extra cap or two on the power line may not hurt either...
