ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.29.2007, 05:34 PM
yep - the pegs should stick out a slight amount.
the RR slipper can be purchased at tower - or mike can maybe get a setup for you. the strobe can be purchased here. not sure about the HSR deal - procharged can get you that info.
again for the strobe, though, you're limited to a 51t spur... i don't think there is a pinion low enough to match a ratio that the HV will handle.
Eflite Blade 400 heli on 3s
