05.30.2007, 11:44 AM
It also depends on what ESC/motor you are running. ESCs are only rated for so high voltage-wise. And depending on the motor kv, running higher voltage could exceed the rated RPM.
If racing, you probably want a lighter setup, so I wouldn't use parallel packs unless you absolutely need long runtimes and/or need more current capacity.
