Originally Posted by BrianG
OK, did you set the trim to centered and EPA to 100% (if available)? When calibrating the ESC, it needs to see a certain range of throttle throw. So, if you have the trim off center and/or EPA set funny, it might not want to calibrate.
Thank you very much Brian, I will try this when I get home.
Nick
