05.31.2007, 05:08 PM
i think the delta peak is preset from the factory, and can't be adjusted. because this charger is so infamous for false peaks (which are harmless... just keep peaking them until they're fully charged) the delta peak is prob. really low. if you set it too high, you run the risk of frying your packs.
