GorillaMaxx360
GorillaMaxx360's Avatar
05.31.2007, 09:37 PM
Originally Posted by jamesbernatchez
Yeah I would get a balancer for which ever lipo I use. I actually dont plan on going the gorillamax route and plan to use the rc monster motor mount with the stock chassis(or the vantage cf chassis).
Im thinking more along the lines of a NEU motor and high end esc. Im only planning on using the Mamba Max if I convert the CRT .5 :)
With 4S would that be 14.4v and whatever mah the pack has? So your saying im better off with the higher voltage in the revo?
Yes when you jump up the size votlage goes up to. 11.1volts would be plenty for a 1/10 scale stadium but for a monster most people here would run at lest 14.4 volts or more. A good high end esc for your purposes would definatly be the quark 125b. SOme have heating issues with this esc but this can be fixed fairly easy. And once this problem is adressed you will love the esc and it would be very smooth and reliable and definatly one of the best on the market for monster trucks.
