06.01.2007, 03:29 PM
I also let it cool off and tried it again later, but the brakes did not come back to normal. Had Mamba set at 50% with radio at 75% (37.5% total) and it would lock em up with most tires. I tried setting the brakes up to 75% now on the Mamba, and it stops good, but still won't lock em up. I haven't got the temp probe out to check actual temps, but it was normally only warm to the touch, now it is hot to the touch (no thermals that I could tell). Buggy is Sportwerks Mayhem.
*edit: also noticed some cogging at low start speeds now, used to be real smooth.*
