crazyjr
crazyjr's Avatar
06.01.2007, 06:14 PM
I wasn't sure exactly which to get so got both and figured i'd ask before using them. One is called super thermal silver compound, and the other is called high density thermal compound. The super thermal is called artic silver 5, and the high density is called cramique. I was just wondering which i should use.
I also found these and was wondering if they will work on the side of the Quark esc? http://www.radioshack.com/product/in...tId=2216875&cp If not, no big, but thought they might help. and last Question before i start, I was looking at the instructions and see in the hard lipo and normal lipo the cutoff is 2.7v per cell, to change it you need to go to manual and that will mess up using the normal lipo. Will it be ok on 2.7v per cell
