AAngel
06.01.2007, 06:18 PM
I don't think that I mentioned it before, but it looks like your running a Feigao/Nemesis motor. There are optional aluminum center diff bulks. If you use these to fasten your mount to, it will be more rigid and help to channel the heat from the motor mount, through the diff bulks to the chassis and will get you more runtime before the motor over heats.
