Quark 125 - cutoff settings....
10kman
10kman's Avatar
Quark 125 - cutoff settings.... - 06.02.2007, 09:48 AM
Hey everyone -
On a Quark 125, there is a battery selection, and a LiPo cutoff selection, which is next in line when programming.
Unless you choose Manual for the battery selection, there is no need to choose a LiPo cutoff voltage (manual says this).
If I choose LiPo Normal for my battery selection, is it using 2.7v for the cutoff by default, since it isn't necessary to set it? Same question for LiPo High, does it default to 2.7v cutoff? Is the 2.7v a safe level to cutoff at, to avoid damange to the packs?
If I set the battery selection to Manual, and set the cutoff to 2.7v (or whatever is a safe level), is it using a profile similar to LiPo Normal, or LiPo High?
Darn manuals..... Darn over-thinking......
10k
